grahamsf
XL100 Display Problems
My XL100 has been working fine post Vista but today suddenly the resolution is screwed and the display is also larger than the monitor.
I have tried all the different display settings and resolutions but this is not working. I have tried to download the latest video driver from the vista upgrage page but this just appears to be a dead link.
I've looked at other posts and tried to change the settings in the Nvidia control panel but under Video and tele I do not have an option to 'Change the signal or HD format'.
Any ideas what I should try next? I have a Bravia 40" LCD and I am connected by HDMI.
grahamsf
I got this working again by completely removing and deleting the nvidia driver using device manager. The screen goes black which is a bit scary but after rebooting vista found the latest driver and the problem was rectified.
I'm using 1176 x 664 which seems to work just fine.
What version of the nVidia driver are you using? - it sounds a bit unstable.
:thinking:
