Hello! I have Sony Vaio PCG-F707 (Intel PIII 600MHz, 256 ram) with Windows 98SE in German language! I want to install Win XP(english version). It's ok? It will work? Thanks! (sorry for my bad english :smileysad:)
Solved! Go to Solution.
Hi uskatu - your English is fine.
It is possible to install XP on the F707 but Sony do not supply drivers and utilities specifically for XP for your model.
I think most W98 drivers and utilities will work OK but you may have to search for some individual drivers from other Vaio models to get everything to work.
