Hi there,
I really want to buy a y-series laptop, but unfortunately it shows "out of stock"... does anyone have any idea that when will they be available?
Many thanks
Solved! Go to Solution.
No, unfortunately Sony never releases such information.
All you can do is to look at the website as often as you can to see if it comes back into stock or is replaced by another model.
You can always look for any second hand laptops in the Internet. You will surely find one by simply searching it in Google.
