Hello, I'm searching for a pair of headphone that is 2 in 1 built: with walkman (playable audio files stored on it) and as a simple headphone to be able to listen music/movies from my other devices: PC, laptop, etc... I see https://www.sony.com/electronics/walkman/nwz-ws610-series/buy would be what I need, but does it behave as basic headphone to connect it to my PC/laptop to watch movies? If yes, then can it be purchased from Romania? Thanks!
Hi there,
As this is the UK Community for all things Sony Electronics, I would recommend posting your question over in the Sony Romania forum here for further help and advice.
Best wishes,
Sean Mc
Thank you Sean,
I was just hoping for a simple recommendation (or more recommendations, of course), regardless where I'm from or what flag this community has.
When I created my account I think I already selected my country, and then I simple listed the question which appears to be listed here, and as everything was in En, I also wrote the questin in same language.
But, thanks anyway, this changed my mind completely.
Once again: very helpful reply!
Kind Regards
