boombox ZS-RS70BTB manual
nodrog47
I have just purchased this radio but it does not have a manual in the box,Contacted Argos who advised me to contact Sony they said that Sony do not supply hard copies with any products but advise using simple print pdf.https://www.sony.co.uk/electronics/support/res/manuals/4470/44705431M.pdf But try as I might I cannot print to A4 sheets when selecting print option I get 2 A4 copies with text so small it is unreadable.
It is not possible to change any pages in adobe acrobat as file is protected,
Can anyone who as come across same problem offer any advice
thanks
Pascale_F
Moderator
Hi nodrog47,
I'll see if i can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
