Hi all,
Any information if I can pair the XB33 with X11 or BSP10? Somehow to create a party mode, which seems to be available in music center for the new speakers.
Or the older speakers can be paired somehow? Do they support music center?
Thanks.
Hi alexdon,
only newer speakers support this software so it won't work with older devices.
Peter
Hi @Peter_S. @,
Thanks a lot for the reply. What about pairing BSP with SRS? The old ones. I know two old SRS is possible.
Thanks again.
No that's not possible. Plus BSP is an xperia product while SRS is a sony product. that answers it all
Alright then. Thanks.
