BT headset WH-CH700N multi device pair (listen & phone calls)
profile.country.BG.title
lightyagami111
Hello alls,
I am asking for WH-CH700N model but i'm not very familiar what part of described points below depends on the headset and the supported bluetooth/connectivity profiles of the same headset.
1) is there a way to listen music/videos on desktop pc through headset and if i get income phone call (while listening) to switch (i.e. switching input source of the headset) the from pc to the mobile phone and answer through the headset? And after close the phone call to continue to listen from desktop pc?
2) is there a way while play music from my phone in the car - the phone is BT connected to audio system in the car and output of the phone audio is the speakers of the car - if i get income phone call (while listening) to switch the audio output from car speakers to the headset and be able to hear & speak.
I will be truly grateful if You guide me what I should looking for and what I should to do.
Best Regards!
Pascale_F
Moderator
Hi lightyagami111
It's best to contact
Sony Support about this.
Thanks,
Pascale
