Can the user replace the internal battery of the MDR-ZX770BN headphones? If so, which battery is it and how would I do so?
If not, then how much does it cost to get the battery replaced using the Sony Technology Centre in UK?
Thank you!
Hi there
According to the manual HERE :
"If the life of the built-in rechargeable battery drops significantly, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery."
Sony repair centres can be found:
http://services.sony.co.uk/support/en/repair/asc
However I have just seen this YouTube clip - although I dont know the model of the headphones in the clip, but was wondering if it was as simple as this:
It probably isnt, so recommend a Sony repair centre in link above.
