Cannot register new headphones
ItsMikeE
Bought the new WH-1000XM3
Went to register - start typing in the product name and it appears as an option - I click on it to select it and it appears in the product box
Fill in the rest of the details and when I click to register it tells me my product is invalid
ItsMikeE
Just registered mine
Presumably they had not added the details to the database until now
11 REPLIES 11
Gijsphdb
Same here. Contacted Sony but no result yet.
Very strange.
profile.country.NO.title
OSvedman
Me too.
psingh02
I bought new WH-1000XM3 online and it was delivered today.
I am trying to register the product after creating the account and it shows that the product is invalid.
jumpsuit
Hi to all :slight_smile:
Its  probably just  a glitch, I will pass it on
to the powers-that-be to check.
If I hear anything I will post back here.
ItsMikeE
Still the same problem
hjs8hshi23
Hello,
Same problem here while trying to register my new WH-1000XM3, I thought it was just me entering a wrong serial number or something but it seems others have the same issue (possibly headphones are too new and they're not in their database or something).
Just to be 100% sure, how do I find the serial number on these? I couldn't find it on the headphones itself.
Do I just enter the "S01-#######-E" thing at the bottom right of the box near the barcodes?
Thanks for the support and sorry for the probably silly question.
Gijsphdb
Same problem.
ItsMikeE
hjs8hshi23
Is it fixed? I can't try right now but would be good if it's sorted :slight_smile:
