cannot remove files from NW a35
chwalke19
Have been trying to remove old music files from NW A 35 player. I've done factory reset and format but they are still there. How do I get rid of them?
Thanks in advance.
Sean_Mc
Moderator
Hi chwalke19,
That's very strange as all files should be deleted with a factory reset.
You can try deleting tracks from the Walkman manually.  More details here.
Thanks,
Sean Mc
chwalke19
Thanks for your reply. You are right, doing it individually has solved the problem.
