Hello,
I've currently got a CDX-G1001U unit in my car. It's been in the car for about a year, maybe a little more. Recently had some work done on the car and this involved disconnecting the battery. Since then the stereo will switch on, play for about ten minutes, then it shuts itself off. I've been trying to get hold of someone to look at it but with no luck and I'm off on a long journey on Thurs, so would like some music to keep me company on the way.
Can anyone suggest what might be going on here? Is there anyone out there who can suggest a remedy for this? I have looked in the manual and can't find this listed in the troubleshooting section.
Thank you.
Hi there,
Welcome to the community.
We will look into this for you and let you know when we have more info.
Meanwhile, some of our members may be able to advise you.
Best wishes,
Ed
Hi musiclessanddesperate,
That's very strange. Have you made sure that the connections are set up properly. There's a dedicated installation guide available through this link: https://bit.ly/2XLaLJ9.
Cheers,
The_Black_Rose
Thanks for the link, that's really helpful. I will check it out.
