CD to FLAC conversion
Bannerman_Photography
Can anyone reccommend a high quality CD to FLAC convertor. I currently use 'To FLAC Converter' purchased from the Apple App store but feel that the sound is not quite as good as the original CD. I would be curious to hear what others are using and their opinions. I am using the NW A-45 walkman and a Macbook but do have access to a PC (windows)
best regards
David
4 REPLIES 4
Pascale_F
Moderator
Hi Bannerman_Photography,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Sonyvores
If you have itunes just stick to AIFF since A45 is compatible
If you really want FLAC then use sony Music Center for PC to rip cd to flac
Hi Sonyvores,
                         Thanks for your assistance, I will give them a try
best wishes
Bannerman
Hi Pascale,
                   Thanks for your assistance, Sonyvores has given me a couple of things to try, I will be exploring these
best regards
Bannerman
