Charging Bluetooth Wireless Haedphones
bob222
Hi All.
I have just bought these headphones, model MDR-ZX330BT. The instruction leaflet states charge using USB port on computer. Is ther any reason for not using a USB phone charger giving output of 5.3v 2.0A or the USB port on my Bravia TV. Replies with advice would be good
Thanks. Bob222
31 REPLIES 31
It doesn't make the bloody difference. It's the USB standard. 5V input/output. Doesn't matter if you plug it t your desktop, laptop, phone, power bank, TV, game console or nuclear plant as long as it has a USB Port.
Tammo5151
Hello thanks for your help it was just that Sony stipulated that you had to use a computer to charge your headphones
jessie1998
So when you tried using your traditional wall plu in charger, did everything go okay?
bob222
Yes they are still working after 2 years b either using the mains usb adapter or usb on the tv.Sent from my Samsung Galaxy smartphone.
Tammo5151
Hello thanks for your help that was good to know cheers
Sent from my iPad
Billghon
I tried to USB charging device and they still shut off after about 5 minutes of noise cancelling mode....very frustrating....
Sent from Yahoo Mail on Android
mattp72
Unbelievable poor customer service from Sony. Who's carrying around a laptop these days??
It should be easy just to tell what technical standards a usb charger must have.
I am still able to return the headphones. Guess it might be what I have to do. If I for some reason will have to use the guarantee, I don't want to be told it's not valid because I didn't charge the headphones in a proper way.
bob222
Hi mattp77I have been charging from USB port on my Sony tv an had no problems. Phones still working fine.Sent from my Samsung Galaxy smartphone.
Billghon
I guess I need to haul around a 60 inch sony flatscreen to charge the headphones? Listen Sony, give us refunds. This is an absurd hurdle to have to deal with. I even bought a USB charger and it didn't work!!!
Oddjobs1942
I have a new set of headphones MDR-XB70BT   I would like to know if it is OK to charge them with a charger used to charge a iPhone or indeed a USB socket found in hotels etc. as plunging them into a computer seems very inconvenient.
