Disable USB charging when NW-A45 is connected to PC?
profile.country.SE.title
SkinnyCyclist
Is there a way to disable charging when the player is connected to the PC? I recall there is a DAC setting regarding this, but will that also disable charging when not in DAC mode?
😊Richard
Pascale_F
Moderator
Hi SkinnyCyclist,
You could try contacting Sony Support about this - they should be able to advise.
Thanks,
Pascale
