- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I am looking to purchase wireless headphones and like the reviews for the above - my question is
I have both my vigin box and sony blu ray player connected direct to the sony soundbar HDMI slots and an HDMI cable from the arc out on the soundbar to the arc in on the sony TV as illustrated in the sony set up leaflet and everything works well changing between TV HDMI1 and HDMI3
how do you connect the above earphones to the system - if as I suspect its with the optical cable from headfones to soundbar - will this interfere with the other equipement?
the soundbar does have NFC and bluetooth _ though i have never used these.
I am looking for a set that I can use in the evenings when watching blu rays or music without upsetting my neighbours
hope someone can help
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi rikthered
Many thanks for replying to my post.
I note you have a similar set up to the one I use and have no problems, from reading your reply it seems the best way to connect headphones is to the optical slot on the tv to the base station.
Thanks for this info it does make things a good bit clearer
Thanks again
Novice
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a blue-ray box with surround sound connected to Sony TV using HDMI/ARC and a Virgin Tivo box connected to the TV on another HDMI port. Via the various TV and Tivo settings I can listen with surround sound to TV movies or DVDs without changing any settings. With this setup, I can use these headphones by connecting the base station directly to the TV's optical out or to the Tivo optical out. They sound great btw.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi rikthered
Thanks again
Novice
