Hi R1colin,
Welcome to the community.
We'll look into this and get back to you when we can.
In the meantime, some of our members may have some tips to share.
Best wishes,
Ed
Hi R1colin,
That's interesting! Are you connecting any other external devices to the speaker? Is there any specific pattern for this behavior?
Meanwhile, I'll try to look this up online to see if any of the users had a similar problem.
Vanilla_
Hi R1colin,
I've been checking any similar issues with teh speaker, but couldn't find any. Are you sure you've had the speaker reset like it says on the User manual here: https://www.sony.co.uk/electronics/support/res/manuals/4597/c0e864310273cfb28d79f7bd428a3b40/4597264...? It's on Page 26
Also, after the reset while no devices are paired/connected to the speaker, do you face the same problem?
Vanilla_
