Help, I want to connect wireless headphones to my tv but can't figure out how
Alanthompson23
I have a KD-43XE7073 tv and a HT-MT300/MT301 soundbar but can't figure out how to connect a set of headphones that can remain plugged in permanently . I have both the tv and soundbar connected through the optical connection of which there is only one of. There is a 3.5mm jack plug but it's awkwardly placed and I'd prefer to figure out an option that would remain constantly plugged in. Is it possible to connect through the hdmi arc and if so what model of headphones uses this socket?
7 REPLIES 7
Sean_Mc
Moderator
Hi Alan,
I'm not sure about this and would advise contacting the Support team for further advice here.
Thanks,
Sean Mc
micking80
Hi Alan
I have recently set up my Sony KD-55X8509C TV with wireless bluetooth headphones and they work brilliantly.
Firstly you need a transmitter/receiver to send the bluetooth sound from TV to headphones. I bought the Trond 2 in 1 V4 1......https://www.amazon.co.uk/TROND-Bluetooth-Transmitter-Receiver....cost £22.99 but think it costs a couple of £s more now. Because it was compatible, I also bought the Trond Wireless Bluetooth V4.2 Over Ear Headphones also from Amazon and they were about £42.
Setting up was not easy for me but Trond Customer Support were very willing and helped me (in a series of emails) to work out what needed to be done. Pairing of the transmitter and headphones is straightforward. The transmitter is then connected to the TV headphone socket using the 3.5mm audio lead. I understand this set up is peculiar to Sony TVs so it might be different for other TV makes. The headphones are comfortable and the sound quality is very good but the volume controls are a bit fiddly. That said there are absolutely no lip sync issues.
Hope this helps
micking80
Hello Alan. Have you had any luck in setting up headphones etc?
micking80
Have you managed to sort out your headphones issue?
Alanthompson23
No not yet
Sent from my iPhone
kelittl20
go to currys  they have plug in to headphone socket  and at the end of that acradle to hang them on with recharge for batteries as they are wireless  {plug and play}
used these for years  sony panasonic and no doubt higher end  but i find these adequate
Alanthompson23
Thanks I'll give that a try
Sent from my iPhone
