Help with car stereo fitting
quiche_nufc
I've just bought the Sony wx-920BT and fitted it into my ford focus.
The surround supplied does not fit the fascia adapter for a ford.
EdwinaU
Moderator
Hi and welcome to the community, Quiche.
It would probably be best to talk to the support team for advice about this. You can reach them here.
Cheers,
EdwinaU
thewildswan
This Unit is NOT a 2 DIN unit.  2 DIN is 4" high (101 mm), this is 113 mm high and so I had to cut part of my dashboard away to get it to fit.  Then I had to modify the facia (trim replacement) to allow the craddle to go into it.  What should have been a 30 minutes job took me three hours!!!!
You shouldn't sell products like this anymore, stick to the standrads Sony.
Sack the person who thought that this was a good idea / allowed the designer to make it this size.
