Help with nwz-x1060 transferring (silver surfer)
123toby
HI anybody
Iam trying to transfer audio book (discs) on to the player, say thers 12 discs with 12 tracks per disc but they are all over the place sometimes the tracks doubled or the discs are not in order. I would some simple instructions on what iam doing wrong?
Papillon
Tags (1)
Drumzman
Hi Papillon,
I think what you need to do, before you transfer to the Walkman, is make sure each of the 12 discs has a unique disc name (e.g. you could try putting 01, 02, 03 etc at the end of the disc title for each disc - that way if they all have the same name followed by a two digit number they should play in order).
Make sure you then play 'by album' (just in case any of the tracks across the 12 discs have the same name as well (e.g. Chapter 1)), and then I hope you might be OK.
