I have 2 ICD SX2000 voice recorders that I use regularly and I also have the ICD UX533 recorders.
There is a feature on the UX533 that currently doesn't seem to be on the SX2000 model which is the copy all function.
I was hoping to copy all of the files from the built-in memory to the SD card as the recorder doesn't support .wav files recording to the SD.
Currently if I need to copy files I have to do it one by one.
The second question is will there be a function to listen to the recorder over bluetooth using the rec remote? I can see the levels however I cannot hear it over the rec remote using headphones.
Is there any chance that is already available somehow or will it be available in the near future?
Thirdly, if there is a possibility to rename the bluetooth name for the voice recorders so that when I go to connect to them, I can connect to the right one.
Also if you could fix the glitch so that record remote can at least still see the wave forms when recording through a mono microphone as opposed to stereo, that would be great.
Kind regards,
Matthew
