Loading ALAC file from iTunes on my Mac to Walkman
wolfiewolfie
Hi
I guess that this may be an old chestnut that has been raised many times.  However, I am looking to buy a Walkman but have all my music files stored on an Apple Mac in ALAC.  Will I be able to load these onto the Walkman (A45 or A55)?  I have read elsewhere that you can load iTunes, but in an ALAC configuration, I don't know?  Any help would be welcomed.
Roger
Peter_S.
Genius
Hi Roger,
Both Walkman support Apple Lossless format.
Please refer to:
A45: (ALAC, 16 bit, 24 bit / 8 kHz - 192 kHz)
https://helpguide.sony.net/dmp/nwa40/v1/en/contents/TP0001449072.html
A55: (ALAC, 16 bit, 24 bit / 8 kHz - 384 kHz)
https://helpguide.sony.net/dmp/nwa50/v1/en/contents/TP0002342895.html
Peter
Peter_S.
Genius
Hi Roger,
Please refer to:
Peter
wolfiewolfie
Thank you very much for this.
Was it the earlier A40 and A50 that had problems with ALAC?
Also, do you have a A45 or A55?  Are you happy with the performance.  I am looking to use with a bluetooth speaker (Vn 4.2, i guess).  Do you know which ones within reason, perform well with the Walkman? Please accept my apologies for these questions but I like to have my information in place before purchasing.
With thanks
Roger
