Ls-s50gw
Mikesme7
Ls-s50gw
LF-S50G .. Google continued conversation,  Installed but does not work, ?
Pascale_F
Moderator
Hi Mike,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
4 REPLIES 4
Pascale_F
Moderator
Hi Mike,
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Mikesme7,
I've just had a look into Google's official website and I can see that this feature is only available in the US. I recommend checking this http://bit.ly/2SUxGn6.
Cheers,
The_Black_Rose
Mikesme7
Thanks for your support.. Sony seem Reluctant to  specify whether LF-s50 Smart speaker supports continued conversation or not, in the Uk  Good  Smart looking speaker  needs   More Google Home updates to stay with the market leaders  regards
mikesme
The_Black_Rose
Specialist
Hi Mikesme7,
I see what you're saying, yet, we need to bear in mind that the availability of the feature in certain countries is considered Google's decision more than Sony's.
Cheers,
The_Black_Rose
