I am looking for a main charger for the walkman NWZ- A-15 but all i can find is this: https://www.amazon.co.uk/d/Laptop-Chargers-Docking-Stations/Mains-Travel-Charger-Walkman-NWZ-A10-NWZ....
Sony used to do a mains charger AC-UD20 but i don't think this is available now?
Any thoughts?
Solved! Go to Solution.
You can use your smartphone charger for your walkman, no problem 😃
What smartphone has the same connection as the walkman?
I bought the charger from Amazon & it works fine.
Do you need a charger or a walkman cable??
