Hi, when i get a phone call people can't hear me well, they hear the other people around me bättre. Is any button i have to use when i get a phone call?
Hi, it happens when i'm in the steet or subway... I¨ll check your linking. Thanks.
did you solve the problem?
I am facing the same in my office, people cannot hear me - at least as long as by co-workers are talking as well.
Hi
Have you both tried a reset on your headphones in case that helps rectify the problem?
Another member. @Agresvig, posted the instructions in This similar topic
I have re-started mine as couple of times as per instructions.
Does not help for me.
I guess that there is a HW-issue on some units.
My headphones are unusable for calls unless it is quiet around me.
