MDR 1000X stopped charging
alessio.macri
Hi there,
I own a pair of MDR1000X. Everything always worked fine until yesterdat when they suddenly stopped recharging. I tried to plug them while they were running low with different cables and usb plugs but nothing seemed to work. They just won't charge anymore. I was wondering if there is anything I could try to solve this. They've been quite an expensive purchase so I would like to get them fixed.
Thanks!
4 REPLIES 4
IamNic
Hello @alessio.macri,
have you tried to reset the headset?
Here you can read how a reset is performed:
https://helpguide.sony.net/mdr/1000x/v1/en/contents/TP0001176174.html
https://helpguide.sony.net/mdr/1000x/v1/en/contents/TP0001176175.html
- Nic
alessio.macri
Hi Nic,
Thanks for your respnse (sorry for the late reply, I had login issues).
I did both, now they are factory-reset, but still not charging 😞
Sonyvores
How long have you been using it?
if it doesn't charge, does it work while plugged?
IamNic
Then it is probably best to get in contact with the service.
- Nic
