My MDR-100abn headphones are paired and connected to my macbook air, but there is no sound. I was wondering, is bluetooth pairing compatible with mac? Or is it only for windows? If it's compaatible with mac, why is there no sound?
I've tried restarting my mac, resetting my headphones, resetting headphones to factory settings, and re-pairing my headphones with my mac. Nothing worked.
Solved! Go to Solution.
Hi there
The MDR-100abn supports for the following bluetooth profiles:
You will need to find out if your Mac supports those bluetooth profiles - mainly the A2DP and HSP
Hi there
