Is there any way to check the battery charge level on my MDR-XB950 wireless headphones? Other than waiting until they stop working, at which point the charge level can be assumed to be around zero...
Solved! Go to Solution.
Hi Robeatl12.
There's a way using the LED indicator. Here's how to do it: https://helpguide.sony.net/mdr/xb950n1/v1/en/contents/TP0001176127.html
Win_88
Hi robeasl12,
Welcome to the community.
I'm not too sure but I'll see if I can find anything out for you and in the meantime, someone else in the community might have some ideas.
Thanks,
Pascale
Hi Robeatl12.
Win_88
Thanks for that. As is also mentioned in that article, a simple short press on the Power button results in a voice message in the headphones stating the bettery charge level (Low, Medium or High). Just what I was looking for.
