Mex-N5100BT - Cannot disable OPEN APP Prompt
tk007b
Hi there,
Have upgraded my firmware to the latest version (1700) but whenever, I turn on my car stereo in BT Audio mode, it brings up an OPEN APP prompt, which I do not want to see, as I do not want to use the Sony App. I can get rid of it by manually pressing the SRC button but I like to have the track title displayed and need to press the display button about 6 times
Is there anyway, I can keep my desired display ?
Many thanks
MkChabe
I have the same problem and don’t like it! Can’t figure out anyway to disable it! It’s really annoying!
tk007b
Hi MkChabe,
I have resolved this problem by flasing my firmware to the latest version. Once I did this the OPEN APP prompt appears but only for a second and then it goes away. Are you sure you have upgraded to the latest firmware ?
The firmware I used (I have a MEX-N5100BT Car Stereo) was version 2000
Here is the download link
https://www.sony.co.uk/electronics/support/mobile-cd-players-mex-series/mex-n4100be/downloads/Z00054...
I hope this helps .. please let me know
Good Luck
