My walkman B152F has jammed it's back button or thats what I think. I tried resetting it with reset button but no positive results. If the button is really jammed, what should I do to make it normal?
Hi @varunbrahmbhatt14 and welcome to the Community
I think its best to contact Support about this
They may be able to help you identify if its a stuck button or other system
problem you are having.
