NFC Function WH-1000XM3
Jamie88a
I'm curious why the NFC function turns on the headphones, though when I want to turn off the headphones it only turns off Bluetooth?
If there's a way to turn off the device using NFC that would be great rather than holding the button down for 2secs everytime.
Tags (1)
IamNic
Hello @Jamie88a,
NFC is usually just meant as a way for the initial connection between the headphones and a "new" phone.
Once the devices are paired, the headphones will connect automatically to the phone anyways, so there is actually no point in using NFC everytime (it doesn't hurt though).
That the NFC-tag being "scanned" also triggers the headphones to turn on is a bonus if anything, so no, you can't use the scan to turn them off.
- Nic
