NW A105 wiredd output
whads354
My NW A015 does not play through the Aux In on all devices. The wired output on the walkman works through the aux in port on a small speaker I have and works through wired headphones but I can't get it to work through the Aux In on my Roberts mp sound 43 cd/radio/aux in player. The music is playing on the walkman but there's no sound coming out of the Roberts. I can play music from my Samsung phone through the Roberts player so that doesn't appear to be the problem, and I have tried a number of different cables. Can anyone help please?
Joe_Dohn
Specialist
It's good that it's working, but you should probably try clearing the app data and cache from the settings for that app. (android.process.media) If there isn't an app -which I'm suspecting since this seems to be a system process- try going for a factory reset.
This wouldn't be a convenient thing to do, so only start this when you have the time to set everything back up.
Hope this helps!
- JD
8 REPLIES 8
IamNic
Hello @whads354,
which type of wire is connected to your Roberts player? Is it a TRS or a TRRS cable?
- Nic
whads354
Hi Nic,
Thanks for your response. I had to google what you meant but there's two black rings on the head, so TRS I believe.
Steve
IamNic
Hello @whads354,
two black rings is a TRS connector. Is the NW-A105 in a case which might prevent the cable to make full contact? Some plugs have a bigger diameter housing which can get "caught" on cases of smartphones and players.
- Nic
Joe_Dohn
Specialist
@whads354 @IamNic
I was just about to mention the case being a possible cause since I had a similar issue with my phone a year ago and never realized the jack was literally wider than it should be on one end (switching the cable around fixed it, how random is that?).
whads354
Thanks guys but it's not the case. I tried 2 cables, both work playing my Samsung phone through the Roberts player but neither work with the walkman, with it's case off. Bizarrely I have a cheap little x-mini speaker with a trs cable and the walkman works with this. Seems weird to me.
whads354
Thanks for all your advice, but by accident the problem is solved. When I turn on the walkman I get a pop up msg that says "app android.process.media keeps closing" and gives options to either view info or close app. I would close the app. By selecting view info all that happened was the pop up box disappeared and now the walkman plays through the Roberts. The pop up msg still comes up every time I turn on but it is working now.
Joe_Dohn
Specialist
Hope this helps!
- JD
Joe_Dohn
Specialist
Hope this helps!
- JD
