This is a new purchase a few days ago. I have updated the firmware to v1.2 and added files to the internal memory by using drag-and-drop in Windows Explorer. Everytime I start the player it goes through the "creating database" process. This is frustrating enough, but when I put in a 128GB micro SD the time it takes to do that each time makes the player unworkable. I have forced a database creation manually both with and without the micro SD fitted but nothing changes. Can anyone offer any guidance please?
Clive
Solved! Go to Solution.
1. It does bother me, otherwise I would not have gone to the trouble of posting a help request.
2. The help I have had from Sony is limited to telling me to reformat the card. Given that the action is by design, this advice is misleading. Surely the designers of the player know that it is by design and surely they could have told me, but they didn't.
3. My expectations are driven by the NWZ-A15 I have. With the same card, containing the same files, it boots in under one second. I am at a loss to understand why this player takes in excess of two minutes.
4. There is no need to create the database "just in case of a change" each time. It is a very simple matter for a 'fingerprint' file to be created each time files are added, and for that file to be checked. If it is the same as preevivously (so no new files have been added), the database create instruction is by-passed.
5. It would be remarkably simple to allow a user setting to make database creation at start-up a manual or an automatic process.
Hi there
It might be the case of its got a lot of music to go through and its not fully creating the database for whatever reason?
I did find this however:
https://www.head-fi.org/f/threads/new-sony-nw-a30-series.815843/page-35#post-13048173
https://www.head-fi.org/f/threads/new-sony-nw-a30-series.815843/page-35#post-13049478
https://www.head-fi.org/f/threads/new-sony-nw-a30-series.815843/page-36#post-13050565
yes it is by design, it has always been like this in case you added new files to be detected. Only way to avoid that is not to turn off the player. Why do you turn it off anyway? Battery is very large and last very long for a music player and charge is fast so virtually you never need to turn it off especially if it bothers you that much :S
