TheOriginalDuffer
NW A35 Volume
Why did Sony have to cap the volume on this device? It so low!
When you turn it on the volume is at 50 but to get a nice listening level I have to up the volume to aleast 80-85 which then gives me warn beeps. So annoying!!!!!
9 REPLIES 9
Hi there,
Here is the Information you need: http://bit.ly/2miDVz9 Let us know if that helps.
Best wishes,
M
Sonyvores
just google a bit and you can find a way to uncapp it but at your own risks
ozzlywoff
 Recently bought a (nw a35) mp3 player. I have a AC-NWUM50  charger which I used on an older mp3 player and wondering if this will work on my new player without any ill effects as i'am on holiday soon and do'nt intend taking a computer which as far as I can see is the only way to charge.  Many Thanks.
IamNic
ozzlywoff schrieb:
Have you tried charging it via your smartphones charger or a powerbank?
- Nic
TheOriginalDuffer
I am now VERY HAPPY with my NW A35 after uncapping the volume to USA settings.
Now when I turn it on and start listening to music, I only have to raise the volume to 60 instead of over 80 and the sound is rich, full and all enveloping. :smile:
Google : SonyNWDestTool
It only took a couple of minutes to do following these instructions.
jumpsuit
Hi @TheOriginalDuffer
Glad you got it sorted :beers:
The link you provided though doesn't show
any instructions.
Sonyvores
@jumpsuit just click on the link on that page :wink:
But i think it's better to remove the link. As an official forum, it goes against the policies :grin:
TheOriginalDuffer
Srcoll down to Changing destination settings and sound pressure regulation and you'll be good to go.
jumpsuit
@Sonyvores cheers   :wink:
