NW A45 can I connect this to optical in on Extreme Music Soundcard?
Canadianguy54
I have optical in and out with a Toslink or Coaxl cable on the soundcard! Can I run my player through the headphone jack to the optical in on soundcard?
If so, what kind of jack would I need?
EdwinaU
Moderator
Hi there,
We'll look into this for you and update the thread when we know more.
Maybe another member will come forward with some information too.
Best wishes,
Ed
Canadianguy54
Hi.....I figured it out, it was so simple. Can't belieive I forgot this! just using a single rca on each end and then plug one into your Line In and make sure you remember to check..Play Through This Device.
