NW-A45 Micro SD Card which card to use Sony Make or Sandisk + can someone take me to a 128GB Card ?
Graygray20
Hello all
Can some one help me please I have just purchased a NW-A45 now my questions are I need a 128GB or higher Micro SD Card, Do I have to go with Sony or can i use a sandisk Micro SD card
Now my second question is I have about 300 CD's will thay fit on a 128GB and expanding collection
Last question now is which one if sony do i go with as there are many 128 GB sd cards out on different web sites like Pro micro SD 128GB card which cost in different prices
Please help if you can
Many thanks
Graygray20
UK England time zone
10 REPLIES 10
Pascale_F
Moderator
Hi Graygray20, and welcome to the community.
I'm not too sure about this but I can pass this on to the team to look into and get back to you when I have more info to share.
Thanks,
Pascale_F
Sonyvores
For your pocket, sandisk will be better :slight_smile: and more efficient (faster read/criting speed) for the same price.
Well depends of what kind of music you listen to and what is the file you are saving your library. Without knowing thet file time, we can't answer you 😃
Graygray20
Hi i am using flac on 16 bit off the sony music center
Memory card i have in a moment is a 128gb sandisk ultra micro sd card from my mobile the second half of my question is do they need to be 24 bit for the player for even better sound
Thankyou all
Sonyvores
If you rip in Flac then an average album is about 300Mo so approx 3 albums for 1Gb so it should be OK 😃
I don't know if the new software has that feature but with old media go, if you highlight the track you wanna transfer it will calculate the amount of data it represents 😃
If you have 24bit files it will sound better but it will also depend of your headphones/IEM
Graygray20
The headphones i am using are the Sony WH-H900N H.ear on 2 wirelss NC.
All my cd have been ripped to flac via the sony music center and are 16bit how to change to 24 bit if its better someone tell me
Thanks everyone for reply
Sonyvores
you got a pm 😃
databus
Hi, I'm ready to buy a 64GB micro SD card for my Sony Walkman NW-A45. I'm wondering what the outcome was. Do Sandisk work or do I have to buy Sony. I've imported my CDs using Music Centre for PC to FLAC and transferred some to my Walkman along with the cover art. ( The cover art didn't transferr when I used WAV). It all displays as you would expect with FLAC.
Sonyvores
Sandisck is fine, you can even go up all the way to 400gb
Steve585
Hi. Just about to buy a Sony Nw-a35 and was wondering about memory card size. Just to confirm it will DEFINITELY take a 400gb card? Thanks for any reply.
