NWZ-E383 FULL SPACE, NO SONGS
Codrin1
Can someone help me please, i just bought an mp3 walkman and i formated by a mistake i never used, i formated and after that i tryied to put some music on it and after that when i disconect it from the pc its loading creating library after that its saying "not enough free space in memory. Delete files to ensure free space." after that this message dissapear and the menu appears and when i try to play some music from the walkman its says "No songs available for playback. Please connect to compliant software or device and transfer songs." I search on google how can i fix it, many peoples saying this issue can be fixed downloading sonic stage so I downloaded sonic stage but it doesn`t detect the mp3 player. Winamp detecting my walkman i transfer music but i get same issues after that. So is there any chance to fix it? Please i wait for an answer this is really annoying
Codrin1
oh thanks God i finally fix it, it was because was formated NTFS but it must be FAT32 because its only 4gb, anyway thanks for your time my friend
11 REPLIES 11
Catmambo
Have you tried Media Go?
http://www.sony.co.uk/support/en/product/NWZ-E383
Codrin1
hello, thank you for the reply, when i click on media go there is no download button 😞 its just details about it but no download
Codrin1
i forgot to mention from first time, when i try to format the walkman from walkman menu its asking me if i am sure i want to format but the files i put in are still there after built in format
Catmambo
Codrin1
i have downloaded but how can i recreate the database?
Codrin1
i have transfered music into the walkman but still the same issue
Catmambo
Really sounds like you need to start from scratch and reformat the walkman as its impossible to know what state its in remotely
Codrin1
i format the walkman but still nothing
Codrin1
i want to update the firmware maybe this gonna fix the problem, i search on sony website but nothing about this, i search on google also and still nothing 😞 what can i do?
