NWZ ZX1 mp3 player - error message 0x80070052
jeffhenry
After previously uploading 70gb of music onto my new player, it is now bringing up an error message 0x80070052 when I try to load more, saying file or folder cannot be created. I am using Windows drag & drop, player is running the latest version of software, and I have also tried resetting and initializing the player, without success. At the moment I cannot upload any more music. Any suggestions what's causing the error, and how to solve it?
Peter_S.
Genius
Probably you reached the maximum number of files or folders:
http://helpguide.sony.net/dmp/nwzzx1/v1/en/contents/TP0000072174.html
Try to change the folder structure accordingly.
Peter
Peter_S.
Genius
Peter
jeffhenry
Thanks for the information - it worked, I'm up and running again. You're a star!
