over charging my Sony NW -A45
Canadianguy54
Hi.....it's happened 3 or 4 times, that I go to bed and forget to unplug the charger. Does this do any long term problems or is there an auto shut off?
Sean_Mc
Moderator
Hi there,
If you let the battery charge for longer than just the charge time, it will end up damaging the battery over the long term.  I would recommend disconnecting your device when the battery status icon switches to 'Full'.  In answer to your question, there is no auto shut off that I am aware off.
Best wishes,
Sean Mc
captainles
I have the NW-35 which looks very similiar to your NW-45, on my player under Settings/Device settings there is a battery care option which, if selected, limits the charge to 90% of the battery capacity and thus extends the life span of the battery, hope this helps and works for you.
