"Transfers are not allowed" error message MZ-NH1
moonbus
After a hard system crash requiring a complete clean re-install of w2k, my Sonic Stage will no longer transfer many of my mp3 files to Hi-MD (they worked fine before the re-install). The files were placed in an external HD and not affected by the re-install. However the following error message is generated by SS: "Transfers are not allowed ."
What I have tried so far (w/o success): editing/removing mp3 tags. Letting SS go online to verify whatever it verifies on the 'GET CD INFO' server.
The files were not downloaded from any online server, they were all ripped from CDs using Nero. The files are not copyright protected (they transferred fine before the re-install).
Converting the files to wav format using another app (SS refuses to do that too), allows transfer to Hi-MD, but I get only 5 - 7 tracks onto a MD; I bought MD to get more, not less, music on a disc, so converting everything to wav format is not practical.
The previous version of SS which delivered with the Walkman will not now re-install. I was forced to install a newer version of SS, as below:
SonicStage : 4.3.01.14050
SonicStage Add-on for MD Walkman : 2.0.05.15180
OpenMG Secure Module : 4.7.00.12140
MagicGate Memory Stick Device : 4.7.00.12140
NW-E2, NW-E3, NW-E5 and NW-E8P : 4.7.00.12140
OpenMG CD : 4.7.00.12140
M.S. PRO : 4.7.00.12140
CD Walkman : 4.7.00.12140
ATRAC Audio Device with Intelligent function : 4.7.00.12140
Hi-MD : 4.7.00.12140
Music Clip, NW-S4, NW-E7 and NW-E10 : 4.7.00.12140
ATRAC Audio Device : 4.7.00.12140
Net MD : 4.7.00.12140
EMD Plug-in: 4.3.01.14020
CD-R Writing Module(Audio CD/ATRAC CD/MP3 CD) : 4.3.01.14050
Px Engine: 3.4.36.500
Sony Walkman MZ-NH1
W2k SP4
Can anyone suggest what to try next?
Message was edited by: moonbus
moonbus
I have devised a workaround (trial & error): by saving the original mp3 files in mp4 or wma format, then re-importing them into SS, I find that SS is able to transfer them to the Hi-MD device. This is tedious in Nero Wave Editor, one track at a time with lots of manual clickityclicky. Does anyone know of a batch file converter to automate this task?
profile.country.FR.title
ClarkLong
MZ-NH1 doesn't support native mp3 files, SonicStage has to convert it into atrac file to be playable on NH1 :wink:
Since u r using W2k os, I don't get how come it doesnt work well weirdo...
