some engineering defect
kishan52
I just purchase WF-XB700 Truly Wireless Headphones with EXTRA BASS, thanks for your this amazing product, everything was just amazing but only one engineering defect, in the output of a sound waveguide there should be a protecting cover but it's not available, protecting cover required becauseno cover on sound out putno cover on sound out putno cover on sound out putno cover on sound out putsound wave guide is open so please cove itsound wave guide is open so please cove itmake rubber sleevemake rubber sleeve when the dust is going inside. it is stuck with magnate as well as diaphragm and the sound quality was going down so please correct this fault, so this can be value for money for a long time, if ist possible to make ear touch surface rubber-type surface or sleeve then its make so comfortable and make good grep with ear skin, and it can be  IP65 then it's amazing thanks,
Regard,
kishan edited[personal details removed]
Peter_S.
Genius
Hi kishan,
If you add something to the sound channel it will affect sound quality.
So I'm not sure if this would be a good idea.
Peter
kishan52
ya that's true but u can also add filter like that that cant be affect sound quality, but when dast goes in then, it cants away because of magnet so its need to cover it, is dust is stuck with diaphragm then already sound quality was going down, thanks
