sonic stage
Bonbibi
sonic stage
How can I convert my all of my sonic stage music files to Mp3 files to use with other software ?
All my music is stuck!
SonicB
I am new to this site and this is an older post. I was wondering if you made any progress?
I know of no other way than through SonicStage to process the digital tracks. It can convert Hi-MDs (SP or LP) to WAV format and in turn you can use another software suite such as iTunes or AVS audio file converter to create your MP3's
That's not the end!  If your discs are in MD format even Sonic Stage will not let you import. This is the way around it all. No Sonic Stage needed.
Import the sound as audio into an audio editor such as Audacity, Magix, AVS, via a 3.5mm jack lead from the headphone sockets. It's longer this way but can be done. Then you can EQ and edit the various tracks adding their names etc. Yup it's a long job - but you can do it.
I hope that helps you. It doesn't help me much as my question is can Sonic Stage run in WIN10?
Regards
BerrG
Sonyvores
depends of the format of the files you have?
Is it ATRAC or WAV or something else?
