Sony HT-SD35 soundbar query ..πŸ€”
dazzatheyid
Hi i have just recently purchased this same soundbar lovely sound, but seems to have an issue with disconnecting when changing channels, mines hooked up to the said Hdmi ARC port also...
Is this normal or am i setting up incorrectly?
Griffin_door
Specialist
Hi @dazzatheyid, did you try to connect via a different HDMI cable?
Also you might wanna check if the software on your TV is up to date or not.
dazzatheyid
If the issue continues I shall try a different HDMI cable yes as I'm aware software updated on TV which is also a sony oled
SkyNet404
Specialist
Hey there,
You can let us know what's your TV model, maybe there's something we can also recommend to do on the TV itself.
Cheers.
