I’m trying to Bluetooth pair my new Sony headphones with my 5th Gen Kindle Fire, but it’s not showing in the Bluetooth list... are these compatible?
Solved! Go to Solution.
Hi @Chettz and welcome to the Community
I'm not sure they are compatible as Bluetooth microphones,
microphone-enabled headsets, and low energy devices are not supported.
I wonder if your headphones class as a microphone-enabled headset
as you can make calls from them?
You may have tried this already but here
are a few things you could try
Note: Bluetooth is not available on Kindle Fire 2nd Generation.
Then:
Let us know if this helps.
Then:
Thanks, I'd seen that too, and thought it could be because of that - oh well. Thanks for confirming my suspicions!
