Sony NW-45 cant find the 1 Terra micro sd card
Obsmusic
Hi! I just bought a Sony NW-A45. For this I bought a Verbatim 1026 gb / 1T micro sd card. When i put it in nw-a45 it fails to find sd card. mounth is not enabled and when I try to format I am told that there is no sd card in the mp3 player. Have checked if the sd card works on my pc and everything seems to be fine with the sd card. What should I do? SD cards are not cheap.
Obsmusic
Problem solved! The SDHC card had wrong format and old files. Then the nw-a45 couldnt find the card at all. I used the program sd card formatter , and the function quick format. IT goes vert quick - about 1 minute. When i insert IT in the mp3 player the sd card is mounted and its possible to format it.
