Hi
I have a problem with the volume playing on my SRS XB-30. When playing via Bluetooth from my iPhone everything can be Ok, but the second I receive a text message or any notification on iPhone, the volume playing on XB-30 jumps to maximum.
Has anyone same problem or solution
Many Thanks
Michael
Hi Mickyd137, welcome to the Community.
You might have to turn the iPhone all the way up to fix this problem, or possibly lowering the alert volume on the phone might help.
It's likely the speaker is responding to the iPhone's alert volume but is unable to lower its own volume afterwards. When playing music, if your phone volume is already up and you turn the speaker down, the problem shouldn't reoccur.
Mick
