Sony Walkman NW-A3000
cgcampbell
I have a Sony Walkman NW-A3000 digital music player and it is still working well. Can someone tell me how I can transfer some new music to it from my PC (Windows 10) and Windows Media Player? I think SonicStage is no longer working and I am getting conflicting advice through Google.
5 REPLIES 5
Marino.Manolo
Genius
Have you try to install SonicStage in Compatibility Mode in Win 10?
cgcampbell
No I have not tried to download SonicStage. I have read on the internet that there might be problems in doing so
Sonyvores
there are MANY topics about your issue within this forum.
Try the "search function" and you'll find your answer
cgcampbell
Hi Sonyvores
I have tried to do what you suggest but could not find a similar topic on this forum. My PC uses Windows 10.
Sonyvores
Sadly sonicstage can't run on Windows 10.
1)Your only possibilty is to have Vista or XP.
2)Your last chance is Win 7 but you need to download (use google) a modified version of SonicStage CP that can run on Win 7. But since it's an unofficial version, we can't help you more on that and if you try it it's at your own risk. I'm using that  method and it's working good for my set up
