Sony Walkman NW-A55L - Amazon UK USB-C
Cyborgbadger
Hello, I was thinking of importing a NW-A55 into the UK, then I noticed www.amazon.co.uk has a NW-A55L for pre-order. The description says it has USB Type-C port? I'm not sure I believe it as the NW-A55 has a WM-port. Can anybody shed any light on this? Is there a difference between the 55 and the 55L?
https://www.amazon.co.uk/Sony-NW-A55L-Walkman-Portable-S-Master-Black/dp/B07X3XD1BW/ref=sxbs_sxwds-s...
5 REPLIES 5
Sean_Mc
Moderator
Hi there,
Unfortunately I'm unable comment on models that are not sold in the European market.
You can see the current range of Walkman available on the Sony website here.
Best wishes,
Sean
Cyborgbadger
Hi Sean,
Thanks for the reply. However, by the look of the Amazon.co.uk, the NW-A55L will be available in the UK on the 1st of November, so was just wondering if there was any more information. Amazon must have got that information from somewhere.
Sean_Mc
Moderator
Hi again,
I don't have any information on this.
Best to keep an eye on the Sony website and social media pages for all the latest updates.
Best wishes,
Sean
QSwitch
The Amazon info is inaccurate.  The A55L still uses the WM-Port.  There's little gain with the USB C on the A105, however - Sony have opted to use USB 2 anyway for some reason, so the data transfer is no better than you'd get through the WM-Port.  It does mean you can use cables you might already have for phones rather than having to carry an extra cable just for the player, but that's the only benefit.
Sonyvores
The only one difference between NW-A55 and A55L is that L version doesn't carry radio. Apart that it's the same
