Sony walkman NWA55L wont connect to sony strdn1080_either by usb or bluetooth.
Jmac98
As ive got everything else sony,thjought i would ditch the ipod for the walkman NWA55l.
However,when i try to connect to my sony STR Dn1080  via USB( with usb-dac switched on) it says device  is not supported 😞
Never mind it will pair by bluetooth i thought..nope wont connect through bluetooth either.
Ipod pairs no problems with amp.
help much appreciatted.
Win_88
Specialist
Hi there,
I've looked into this and it seems that the receive is compatible with USB mass storage devices only: https://helpguide.sony.net/ha/strdn108/v1/en/contents/TP0001221212.html
I found some information about putting the Walkman in USB mass storage mode here: https://helpguide.sony.net/dmp/nwa50/v1/en/contents/TP0002342924.html
Win_88
4 REPLIES 4
EdwinaU
Moderator
Hi Jmac98,
Welcome to the community.
We will look into this and get back to you when we have more information.
Meanwhile, some of our community members may have some tips for you.
Best wishes,
Ed
The_Black_Rose
Specialist
Hi Jmac98,
What happens when you try to connect it?
Cheers,
The_Black_Rose
Jmac98
Sorry for the delay in reply.
When connected by USB  and Dac switched on  it says " this device not supported"
With DAC off ,doesn't even recognise  there anything connect to the USB port.
Have got it to work with Bluetooth (finally) ,but its not the easiest of set ups ,would rather just plug it in,switch amp on press play, without  having to go through GUI on the TV all the time. .
Have also tried RCA to 3.5 mm interconnect,but the volume is really low.
Win_88
Specialist
Hi there,
Win_88
