Can I use the above with music players such as Astell and Kearn if they have bluetooth or are you limited to Android only with these earbuds ?
Hello @Clanpitt,
the earbuds are definetly compatible with music players as well (not just iOS and Android devices), yet since there is no "tested" list of devices the earbuds are compatible with, I would advise you to simply test to pair them with the mentioned players (preferrably in your local electronics store).
- Nic
