Sony WH-CH700N wired connection with mic
profile.country.BG.title
lightyagami111
Hello alls,
It is able to use the headset - Sony WH-CH700N - in wired mode with a aux cable with a mic (4 pole/pin cable) like this one - https://www.amazon.com/BestGot-Headphones-Microphone-Controller-Stereos/dp/B0763HQK92 -
for skype conversation through desktop/pc (i know i should use splitter because my pc support separate jacks for audio and mic) ?
If not can You recommend some similar headsets that I can use with bluetooth and as regular one (wired+audio+mic).
Best Regards!
IamNic
Hello @lightyagami111,
that is not possible, since the connector on the "headphones-end" doesn't have the necessary contacts/hardware to allow a mic-signal to be passed trough a TRRS to TRRS cable.
You can though get a cable with an in-line microphone, meaning it has a TRS connector on the headphones-end, then a microphone ON the cable and a TRRS connector on the notebooks side, making use of the microphone in the cable.
Such a cable would look like this: https://www.amazon.com/dp/B010JI2X0C/
- Nic
